D2 inline thermostat mod ?
Old Nov 18, 2016 | 02:01 PM
  #121
Rlozano's Avatar
Originally Posted by Dan7
Sorry for resurrecting. Can somebody tell me why it is necessary to punch a hole in the thermostat. One of the benefits is the availability of the in-line style thermostat but if you have to punch a hole in it before you can use it that's not going to help you when you're stranded on the side of the road.
It helps in two ways. First, the hole should always be in the 12 o'clock position. This helps when bleeding the system. If the hole was not there it could possibly trap air.
Second, it helps circulate a little bit of water while the thermostat is closed which in my opinion helps to stabilize the temps a little. Without the hole I have seen temperatures go up and down 10 degrees, with the hole it drops the movement a few degrees.
If you got in a bind you don't have to have the hole in there, it will get you home just fine. The hole is to further improve the mod as the thermostat is laying on its side instead of pointing up like in small block applications.
abran
Mar 16, 2015 07:28 AM
silar
May 26, 2013 10:18 AM
A5scott
Jul 28, 2012 11:01 PM
DiscoRover007
Jul 16, 2012 08:58 AM
ATLDisco
Apr 4, 2012 07:00 AM
