D2 Overheat?
Old 02-16-2012 | 03:42 PM
If bottom hose to stat never warms up you might think that radiator is restricted with gunk, and water flow is so slow that it cools way off. It should warm up some as truck warms up. Radiator should be about same temp top to bottom, like within 10-20 degrees, unless bottom tubes are plugged with gunk (then they will be much colder). Of course, if you are in Whitefish MT, conditions could be different. A clogged up $250 radiator can cook an engine.
  #22
Old 02-16-2012 | 07:34 PM
rimasco's Avatar
ha now you got me thinking again.. if I knew for sure whther these dam gauges were accurate.. it would make things a whole lot easier
  #23
Old 02-16-2012 | 10:22 PM
The gauges are not accurate, if your truck has an OBDII port, a scanner or an ultra gauge will tell you a lot more.
  #24
Old 02-17-2012 | 08:11 AM
MrMayorDA's Avatar
Drove to/from show last night NO PROBLEMS!!! WOO HOO! Old stat was JUNK! It was all chipped on top hose inlet and looked fairly gross inside! Got bottom hose to warm up as well! Fingers crossed this may be all it took! Gonna bleed it AGAIN in a few!!! Thanks everyone!
  #25
Old 02-17-2012 | 08:32 AM
Dexcool is what cause the t/stat to chip up. Hope you got rid of that and went green. Also, Dexcool will eat up the coolant pressure cap so replace it also.
bavarian_range89
02-11-2008 08:41 AM
range_rovin1986
03-29-2007 06:43 PM
ajs1iron
03-08-2007 12:22 AM
jakea4d2
10-26-2006 11:10 PM
whitedisco11
04-27-2006 07:42 PM
Quick Reply: D2 Overheat?
