D2a facelift, handbrake cable adjustment.
Hi, pin back ya ears and take note. Don't bother to rip out all of the centre console et al, the handbrake adjuster isn't there, it's underneath the truck buried at the top of the trans tunnel. There are two nuts, the top one is 21mm and the lower is 16mm which is attached/integral to the threaded adjuster. Hold the top 21mm nut and turn the 16mm nut anticlockwise one turn at a time. Be sure to test the brakes for any 'binding' so ensure the all the wheels are on axle stands with the handbrake off. When the handbrake achieves only 3 clicks STOP, it's then correctly adjusted. Have fun, good luck and wear safety glasses to avoid the falling road ****e in your eyes.
CamelChad (04-08-2018)
Hi Best4x4, yep, I've done that already but that only adjusts the brake shoes but not the brake cable, particularly if it's stretched over the years.
https://www.google.fr/search?q=tap+n...0AioU1TQ4_qPM:
Trying to find the second nut you were referring to? This is a picture of my cable and there is only one nut on the cable extending from out of the body.
Trying
to find the second night you’re referring to? This is a picture of my cable and there is only one not on the bottom of the cable extending from the body.
