D2a facelift, handbrake cable adjustment.
Old Apr 8, 2018 | 03:30 PM
OffroadFrance's Avatar
Default D2a facelift, handbrake cable adjustment.
Hi, pin back ya ears and take note. Don't bother to rip out all of the centre console et al, the handbrake adjuster isn't there, it's underneath the truck buried at the top of the trans tunnel. There are two nuts, the top one is 21mm and the lower is 16mm which is attached/integral to the threaded adjuster. Hold the top 21mm nut and turn the 16mm nut anticlockwise one turn at a time. Be sure to test the brakes for any 'binding' so ensure the all the wheels are on axle stands with the handbrake off. When the handbrake achieves only 3 clicks STOP, it's then correctly adjusted. Have fun, good luck and wear safety glasses to avoid the falling road ****e in your eyes.
Old Apr 8, 2018 | 04:16 PM
Best4x4's Avatar
You can also turn a giant nut on the back of the Ebrake assembly itself to tighten the shoes up against the drum.
Old Apr 8, 2018 | 04:38 PM
Hi Best4x4, yep, I've done that already but that only adjusts the brake shoes but not the brake cable, particularly if it's stretched over the years.
Old Apr 8, 2018 | 06:32 PM
Best4x4's Avatar
Yeah those cables are sometimes a PITA. I've bought 2 D2's that didn't even have the darn cable after someone sawed em off vs replace em.
Old Apr 9, 2018 | 03:56 PM
The handbrake cable can be a real PITA on the facelift D2's but to hold the top 21mm nut I found the best tool was a bath/basin nut wrench and using a 16mm crows foot wrench using a 3/8" 450mm drive wobble extension. The day before though spray the area with penetrating fluid and then again the day you decide to 'attack' the job.
https://www.google.fr/search?q=tap+n...0AioU1TQ4_qPM:
Old Jun 16, 2021 | 02:53 PM
Jon.P's Avatar
Trying to find the second nut you were referring to? This is a picture of my cable and there is only one nut on the cable extending from out of the body.
Old Jun 16, 2021 | 02:58 PM
Jon.P's Avatar
Trying
to find the second night you’re referring to? This is a picture of my cable and there is only one not on the bottom of the cable extending from the body.
drillam
Freelander
Sep 19, 2017 09:08 AM
03discoman
Dec 23, 2009 10:40 AM
alanroberts50
Nov 23, 2009 05:57 PM
P Carr
Jun 22, 2008 01:25 PM
ChrisW6
May 19, 2007 12:55 PM
