Freelander Talk about the Land Rover Freelander within.
handbrake adjustment, wheel feels like it's in gear
Old Sep 18, 2017 | 10:07 AM
drillam's Avatar
4th Gear
Default handbrake adjustment, wheel feels like it's in gear
as above, when I try to turn the rear wheel to see if the brake is binding it only rocks back and forth a little each way as if it's in gear. Had my Mrs sit in and depress the clutch, even though it's in neutral but it made no difference.
I read the manual about how to adjust it but can't see how I can check for binding. I know I'm probably doing something stoopid.
Any suggestions please?
Old Sep 18, 2017 | 10:01 PM
XCELLER8's Avatar
because it's all wheel drive the wheel will only move a few degrees forward and back...he fact that you can move t at all may indicate that the brake isnt binding....right then anyway....here in the States they came standard with drum brakes in the rear, if yours is too ,just pull the drum off and investigate further....sometimes a good cleaning is all thats required...let us know how it goes
Old Sep 19, 2017 | 09:08 AM
drillam's Avatar
4th Gear
Thanks for your response, seems to be OK for the now so i'll leave it for a few weeks and remove the drums when I fit new tyres
timbrehse
Feb 21, 2017 07:26 AM
cbwhitley
Jun 29, 2011 04:00 PM
alanroberts50
Nov 23, 2009 05:57 PM
P Carr
Jun 22, 2008 01:25 PM
Aquaholic
Jun 15, 2007 10:30 AM
