Damaged Wires in Steering Column
Old Sep 27, 2007 | 09:54 PM
ajh's Avatar
ajh
Default Damaged Wires in Steering Column
When I was putting things back together two of the purple wires from the ignition got caught under the screw holding the cowl over the steering column (the screw pulled through) and got crushed and shorted. This blew the 15A accessory fuse (and a few more while I tried to figure out what was happening) but once I repaired the wires (checked continuity and taped them for now) now all kinds of insanity is happening.
When I try to start I don't get a starter, I get flashing lights, honking, and general erratic behaviour to the point I can't work on it any more tonight without really annoying my neighbours. I'm assuming it thinks I was trying to bypass the imobilizer or something and has gone into some strange 'mode' but what can I do about it to get back on the road? Please help.
Old Sep 28, 2007 | 12:46 AM
geotrash's Avatar
Default RE: Damaged Wires in Steering Column
Not being a Rover expert, only one simple idea comes to mind. It's a long shot but you might try pulling the negative terminal on the battery overnight and see if that resets the system.
Dave
Old Sep 28, 2007 | 07:22 AM
ajh's Avatar
ajh
It seems just waiting until morning cleared whatever it was. Boy this isn't comforting.
Old Sep 28, 2007 | 07:55 AM
ajh's Avatar
ajh
OK, that's it. Once I get a new house with more garage space I'm buying a Series 3, a Defender 110 in the UK and a galvanized Defender Chassis in Canada and a good sized Diesel engine and building something from the ground up without all the computers. This is just nuts.
Dane!
Nov 8, 2013 05:57 PM
thelokolobo
Jan 23, 2008 04:14 PM
GodSavetheQueen
Jan 9, 2008 06:53 PM
Evian
Aug 18, 2005 11:34 PM
GregS
Aug 4, 2005 01:32 AM
