Dead Disco in the Driveway
Old Dec 8, 2007 | 06:09 PM
Ironman472's Avatar
Default Dead Disco in the Driveway
Today I rebuilt my steering sector and high pressure cleaned the engine compartment. Now it will not start. The check engine light has been on for months due to a failing spark amplifyer and ABS being removed from the vehicle when I added hydra boost brakes.
When the ignition switch is turned on for about 20 seconds nothing happens in the acc. position and the motor will not crank. When the power comes on after twenty seconds the motor spins freely apparently never trying to fire.
Anybody got a clue lost in Escondido.
Thanks Ironman472
Old Dec 8, 2007 | 06:24 PM
okdiscoguy's Avatar
Default RE: Dead Disco in the Driveway
Clean and tighten your battery cables. From there. check voltage in your fuse box in the engine bay...
Old Dec 8, 2007 | 06:38 PM
Ironman472's Avatar
Yep, done anddone. Still dead. Hope it will start after it dries out. It sis not happy about being wet. going to leave battery disconnected tonight. As the turn signals worked without moving the turn signal stalk when cranking the motor.
Old Dec 8, 2007 | 07:01 PM
okdiscoguy's Avatar
Pull your fuse box in the cab and see if it is wet. I had a slight leak that allowed water to get in the box. I could turn on the key and about 20 seconds later, it would start by itself and run. Lights were haywire as well. If you have a leaky grommet coming in the firewall, it could follow the wires back.
Old Dec 9, 2007 | 06:40 PM
Ironman472's Avatar
Update, after sitting for twentyfour hours, still dead. I blew out all the connectors under the hood with compressed air. Checked the underhood and the drivers side fuse panels by dropping them down and checked for any moisture none, checked all the fuses good. But water did come thru the firewall on passengers side and soaked the alarm. I removed the alarm and have it on the workbench drying. Charging the battery (ultima) for next round after work.
Old Dec 10, 2007 | 07:49 AM
If your side markers or turn indicators are flashing, then it is either an inerita switch that needs to be reset or your alarm.
Old Dec 10, 2007 | 10:29 PM
Ironman472's Avatar
Update -Success
Patience pays off. Reassembled the alarm (It wasn't designed to come apart) after it had dried out reinstalled
and I am back in bussiness. Thanks for all of the help and moral support.
joshtwining
Dec 8, 2009 02:42 PM
2000 DII
Oct 21, 2008 10:19 AM
Darover
Jun 4, 2008 07:01 PM
jkid
Nov 16, 2007 08:44 AM
newBrover
Apr 6, 2007 10:59 AM
