DI Drivers door will not open from inside or outside
Old Jun 10, 2009 | 01:46 PM
roverohio's Avatar
Default DI Drivers door will not open from inside or outside
Tried everything..Need new accuator? Drivers door only...are all accuators the same on DI?
Old Jun 10, 2009 | 03:13 PM
No, each door has a different actuator.
Have you tried to pull the inner door panel back far enough so you can open the door from the inside?
Old Jun 10, 2009 | 04:38 PM
okdiscoguy's Avatar
Hold the lock up in the fully unlocked postition. If it opens, I know what you need...
Old Jun 10, 2009 | 10:19 PM
roverohio's Avatar
pullled panel back could not get open. pulled the lock up and still would not open? will try again tomorrow..
Old Jun 11, 2009 | 08:25 AM
okdiscoguy's Avatar
It is tricky, but the door panel can be remover with the door closed. Try to do it and open it from the inside of the door.
Old Jun 11, 2009 | 06:22 PM
roverohio's Avatar
anybody ever by-pass the accuator? I does not matter if the door locks just as along as I can open the door..
Joe
joshp01
Dec 5, 2021 07:50 PM
ToddD
Jun 24, 2012 09:14 AM
Prowler9876
Feb 22, 2010 08:31 AM
