Diagnostics Steps for Key Fob Remote
Old Jun 27, 2014 | 10:17 AM
srockrae's Avatar
Default Diagnostics Steps for Key Fob Remote
The power unlock button in car is working fine but the vehicle has stopped responding to Key FOB. I have checked Fuse 20 under steering column. Can someone give me or point to the diagnostics steps for this?
Old Jun 27, 2014 | 11:47 AM
OCMike's Avatar
I'm working on the same problem. Check out my thread to see what I'm doing. I had to take a break from it for a week, as my truck is currently getting a valve job done. I'll be back to figuring it out next week.
https://landroverforums.com/forum/di...ocation-67688/
Old Jun 27, 2014 | 11:51 AM
abran's Avatar
Is the light illuminating when you push the button?
Maybe try changing the battery to see if its too weak?
Once you confirm the remote is working, you will probably have to check the receiver to see if it has a loose connection.
Located just in front of the rear sunroof under the headliner.
In the end, you will probably need someone with a computer to reprogram/reestablish the link.
That's all I got. Have you checked RAVE for a procedure?
chet
Mar 9, 2009 05:51 PM
smartsigntools
Jan 8, 2009 08:21 PM
joatman
Dec 18, 2008 07:33 AM
love2disco
May 8, 2007 10:50 AM
Jay
Apr 27, 2005 03:49 PM
