Difficulties
Old Jan 14, 2021 | 09:40 AM
Zachinco's Avatar
Default Difficulties
Snapped key piece in driver's door keys are separate for the ignition I had to replace. Piece of key stuck in lock, no way to shut off alarm without being able to turn key HELPPPPPPPP????!!!!
Old Jan 14, 2021 | 11:05 AM
jastutte's Avatar
have you called a locksmith?
Old Jan 14, 2021 | 11:08 AM
redwhitekat's Avatar
drill that sob
Old Jan 14, 2021 | 01:42 PM
Zachinco's Avatar
Default Real help with key breaking
[QUOTE=Zachinco;757545]Snapped key piece in driver's door keys are separate for the ignition I had to replace. Piece of key stuck in lock, no way to shut off alarm without being able to turn key HELPPPPPPPP????!!!! I called the locksmith and I cant afford a new ignition what should I do suggestions??? GO
Old Jan 14, 2021 | 02:47 PM
mollusc's Avatar
It's not clear whether you're able to get into the truck or not. Sure, the key is snapped in the door, but is the door unlocked?
You should be able to pick up a replacement ignition with a matched key from a junkyard or one of the disassemblers on this forum. Maybe try roverbones https://landroverforums.com/forum/me...erbones-80548/
Old Jan 14, 2021 | 04:34 PM
mln01's Avatar
Another guy on the forum whose truck also has the key broken in the door lock is able to lock and unlock his truck using a dime or a penny, or even a piece of mulch stuck in the slot where the key goes (really, I'm not kidding; he is local and I have seen him do it).
As long as the business-end of the key is stuck in the lock, you should be able to turn it using A dime or a penny, or something similar. Wait to try the mulch until you have graduated from beginner level.
Old Jan 16, 2021 | 09:15 AM
mr. choodles's Avatar
I second that. I've done this in the past with a magnifying glass and a pair of very good fine pliers. Look at the where you broke off the the key very closely. Chances are there is a ridge and not a clean break. Use pliers to grab on that ridge and see if you can take the broken piece out. That work for me once. Alternatively see if you can gently turn it. You can use a fine screwdriver too ;-)
Jake Walker
Aug 19, 2019 10:15 PM
MrScruff
Jan 5, 2019 05:57 PM
Beca7303
Apr 27, 2017 12:39 AM
2K Disco II
Nov 9, 2010 08:10 AM
ccvalentino
Jan 11, 2009 08:09 AM
