dII is having trouble starting
read the thread, open my hood and cannot see a driver's side fuel rail.
Reached in between upper intake and firewall and cannot feel a schraeder valve.
My son ran out of gas. I added 2 gallons. It will only start now with a small spray of starting fluid and will run perfectly afterwards. Shut it off and same scenario. I have seen the pics of the fuel rail off the engine and the position of the schraeder valve to purge the air but, i am lost as how to get to it. I can barely get my hand between the upper air intake the and firewall. Any help would be greatly appreciated. 2002 Discovery II SE.
OK here is your test and homework that you need to do to help us help you..
In the morning -
Turn the key to run - but do not start it.
Turn off.
Then turn to run again. Do not start it.
Then off
Then turn to run again - do not start it.
The off
Then try to start it.
If it starts right up - then you probably do have a fuel pump as
you have primed it by running the fuel pump a few times by not starting it.
The finally starting it.
So, go from OFF to on - but don't start..
About 5 times.
Then to off.
The start as normal.
See if then it fires right up
In the morning -
Turn off.
Then off
The off
About 5 times.
Then to off.
Chrisinhouston
11-07-2009 07:35 AM
