disable traction control
RE: disable traction control
Well you have two options. First you can crawl under the truck, lock the CDL then start the engine. This will disable the TC and ABS. Second, you can follow this guys write-up on making a manual switch for the TC.
on
You need to learn how to drive in the sand.
What size tires are you running and at what air pressure.
I have run the dunes at Pismo for years and the last thing any of us wanted to do was to cut traction to our tires..
I got to tell you, you are way off on the direction you are wanting to go.
gamecockdisco
07-12-2010 08:34 AM
rodrick smith
04-13-2007 06:09 PM
