disable traction control
Old Jun 5, 2008 | 09:49 AM
catchmyktm's Avatar
4th Gear
Default disable traction control
I need it gone on my 01 disco. I drive in the sand daily on the outer banks, nc. It working to good.
Old Jun 5, 2008 | 10:04 AM
Chillbilly's Avatar
Default RE: disable traction control
Why would you want it gone?
With out it I wouldn't go very far in sand......without the traction control if one tire losses traction you'll dig a 3-4 foot deap trench and be 'hella' stuck.
Old Jun 5, 2008 | 10:21 AM
Disco2Guy's Avatar
Well you have two options. First you can crawl under the truck, lock the CDL then start the engine. This will disable the TC and ABS. Second, you can follow this guys write-up on making a manual switch for the TC.
Old Jun 5, 2008 | 01:32 PM
catchmyktm's Avatar
4th Gear
In sand you need your momentum, with the abs kicking in it actually slows you down. I have actually had the car stop because all 4 tires started spinning.
Old Jun 5, 2008 | 01:41 PM
catchmyktm's Avatar
4th Gear
Thanks, next question would be how to lock the CDL and where it is lockated. I am new to the disco crowd, but not with out atleast some mechanical skills.
Old Jun 5, 2008 | 02:16 PM
You need to learn how to drive in the sand.
What size tires are you running and at what air pressure.
I have run the dunes at Pismo for years and the last thing any of us wanted to do was to cut traction to our tires..
I got to tell you, you are way off on the direction you are wanting to go.
newfrl
Freelander
16
Aug 27, 2020 06:55 AM
gamecockdisco
Jul 12, 2010 08:34 AM
miamihi420
Mar 11, 2010 03:26 PM
rodrick smith
Apr 13, 2007 06:09 PM
Sean 1313
Aug 30, 2005 10:00 PM
