Disco 11 transfer case fluid change, etc...
Old Jul 12, 2012 | 08:10 PM
Bkreutz's Avatar
Originally Posted by parkerlander
well after filling the transfer case and going for a short drive i parked it in the garage.
came out later to find a nice puddle of fluid on the ground so now I know where all the previous gear oil went. What seals are involved? I see the access cover and there is fluid on the bottom of the bolts but is there another gasket that can leak?
Is there an actual gasket for the access cover or just make one out of gasket goop?
thanks!
Depends on where it's leaking, there are a number of places that it can leak. Some of them can be done with the transfer case in place, others can not. There are 2 side covers, neither one uses a cut gasket, both use FIPG (form in place gasket). One cover can be removed easily (the big rectangular one), the other one (on the output housing forward) can't without separating the trans and transfer. I just resealed mine 2 weeks ago. I had to remove the transfer because the forward cover was leaking (as well as the intermediate shaft "o" rings) so I just replaced everything (gasket/seal wise). Best bet is to clean everything carefully, then put oil in it. Don't drive it at first, just let it sit and see if you can detect the start of a leak. If nothing then drive it around the block and check it. You don't want to drive it too much because then the oil gets thrown around and it's hard to determine where it started. If you haven't downloaded the RAVE workshop manual, I'd suggest it. The links are on the signature lines of a couple of members. HTH
Old Jul 13, 2012 | 09:27 AM
parkerlander's Avatar
Ok sounds great and yea I down loaded the manual. Nice to have that as a reference!
Have you done the rear differential? that is leaking as well. Oh well it is a 99 and I'm looking forward to restoring it to hopefully near new condition.
Cheers!
Old Jul 13, 2012 | 11:32 AM
Bkreutz's Avatar
Cheers!
I haven't replaced the rear diff pinion seal on mine (it's not leaking), but it's a pretty straightforward job.
grussell
Mar 21, 2016 04:45 PM
collin Barrows
Aug 28, 2011 07:13 AM
TheBelly
Nov 1, 2010 08:34 PM
grussell
Sep 2, 2009 06:46 PM
badbowtie85
Jun 20, 2007 05:20 PM
