Disco 2 Getting EXTREMELY bad Gas Mileage
Old Aug 29, 2013 | 08:06 AM
dusty1's Avatar
Originally Posted by jfall
I drive like I have an egg on the gas pedal.
Never faster than 60 mph.
Never go off the line fast.
I got 14.5 MPG today when I filled it up.
Old Aug 29, 2013 | 08:28 AM
mattmo78's Avatar
You could try cleaning your throttle body with a little bit of carb cleaner. I need to do it to both of mine. It won't take care of your exhaust fume smell, but it may help some of the other issues.
Old Aug 29, 2013 | 08:32 AM
Fadysdico - if a scanner is available, plug in and monitor coolant temp. If coolant sensor was unplugged, it would read like -40F. It should read ambient when started, then move up to a normal range. If computer getting wrong signal from coolant sensor, it may be making you run very rich, because it is trying to give more gas to warm up engine.
Normal tune up things, like plugs, new 8mm silicone wires, carb cleaner for IACV and PCV system, and made for MAF spray for MAF sensor, all done when engine cold; these can only help.
Old Sep 2, 2013 | 07:12 PM
FadysDisco's Avatar
4wd High
Hey guys ! Just got it back from the shop . Got oil done and codes read . There was one dealer only code after this . Thanks
Chris-bob
Off Topic
Aug 11, 2011 01:44 AM
Spencerfitch
May 19, 2010 08:05 AM
krigsmakten
Sep 30, 2009 02:01 PM
discoandaboat
Oct 4, 2008 07:57 AM
machinegunner
Sep 24, 2007 11:23 AM
