Disco 2 tranny issues
Old Apr 6, 2013 | 12:05 AM
RANDY04D2's Avatar
Default same p0741 code here...
Had check engine on for about 2yrs. p0714 code. Couldnt find a tcc solonoid part anywhere either.I Just pulled the valve body, no big deal, Pulled solonoid and put 12v to it ,clicks open/closed no prob. Cleaned elect connection solonoid screen and reinstalled. cleaned trans multiplug also. 5miles and light on again, same code. Never had an issue with trans after rebuild 3yrs ago. shifts fine and torque converter locks/unlocks fine....stay tuned, gonna get that engine light out someday.....then the 3 amigos........................
Old Apr 6, 2013 | 11:37 PM
DiscoByrd's Avatar
Donnie where u live but we have bull sh#t emissions Here check engine light fails it got it to pass this year the light only comes on when it stalls but not every time it stalls shifts hard sometimes it's very intermidant
Old Apr 7, 2013 | 08:00 AM
Are you sure your service engine light is on, our trannys will throw codes from P0700 to P0802 if anything is going on with your tranny.
Might want to consider having a shop reset your trannys adaptive memory, that can clear up a lot of weird shift issues although I can't remember if it will have any effect on a solenoid.
Old Apr 7, 2013 | 03:29 PM
DiscoByrd's Avatar
did reset the adaptive valves at the shop. still has intermidant hard shifts .. only code it throws when it stalls is the p0741 silonoid lock out code.. bout to pull the valve body and put 12v to it and clean it really good,, had a good tranny at the shop i was going to steal a lock up silonoid out of and wouldnt you know a dII needing a tranny got towed in and it got sold,... -_-
Old Apr 7, 2013 | 03:44 PM
jfall's Avatar
Try to find out what power source drives the solenoid.
There are probably pins on the transmission computer.
Pull the connector.
Get an ohm meter and see if there are only a few ohms of resistance on the windings of that solenoid from the view from the transmission ECU plug.
Along the way, the wiring may be open or shorted.
I don't have the pin out of that transmission ECU. Nor have I ever had a Discovery II electrical .pdf.
That would be a good thing for you and I to have.
Old Apr 7, 2013 | 08:40 PM
DiscoByrd's Avatar
Pull the connector.
I have all data bet that would have it
rover1334
Jan 14, 2014 07:05 AM
ShadowMerchantBC
Jun 29, 2011 04:05 PM
tornado_735
Mar 17, 2009 12:59 PM
MoNtErover
Sep 24, 2008 08:08 AM
Bene
Jul 10, 2005 09:42 PM
