Disco 2 Windshield Top Moulding Fit Issues
Old Aug 24, 2018 | 11:43 AM
rfhusband's Avatar
Default Disco 2 Windshield Top Moulding Fit Issues
Just used the dealership-recommended shop for heated windshield replacement on my 2003 Discovery II and am wondering if others have had any experience like mine. Could use some advice on how to proceed. The upper moulding / molding (LAND ROVER DISCOVERY 2 II 99-04 FRONT WINDSCREEN TOP UPPER FINISHER DCB101510) was destroyed by the technician so a replacement part was ordered through the dealer. The technician insists it is short by about 1.5 inches, leaving gaping holes at either end which he wants to fill with silicone. I ordered another of the same part from Land Rover and it is the same length, still too short. Has anyone else replaced this part and discovered a trick to making it fit?
Old Aug 24, 2018 | 12:03 PM
Sixpack577's Avatar
You mean the 2 small pieces, one on each top corner, that slide on to the drip rails??
They go on first, then are covered by the large plastic trim that goes down each side of the windshield.
If the side trim isn't in place, it may look like the top corner pieces are not correct.
Old Aug 24, 2018 | 12:21 PM
Dave03S's Avatar
Do you have the end tabs or did they lose them?
Old Aug 25, 2018 | 04:15 PM
rfhusband's Avatar
To answer the above questions (thanks for weighing in):
1. Sixpack577 - The part I was asking about was the strip which runs across the entire top of the windshield but I recognize the drip rail front tips may have been reinstalled incorrectly and possibly broken in the process so I have attached photos of left and right upper corners of the windshield to illustrate the problem. You will see the gaps at each end of the strip. Does that answer your question?
2. Dave03S - There is a tab on each end of the strip which are intact but it looks like mine doesn't extend as far towards the outside edges as yours or is there an additional part which I am completely missing?
Hopefully you can see why I am wondering if the installer has somehow done something which prevents the upper finisher from reaching all the way across.
Thanks for weighing in on this mystery.
Bob
P.S. Sorry I can't figure out how to resize these pictures on the forum page.
Right side upper corner windscreen view - notice the visible gap at the top of the A-pillar
Left side upper corner windscreen view - notice the visible gap at the top of the A-pillar
Old Aug 26, 2018 | 12:09 PM
rfhusband's Avatar
Sorry about the delay - my previous reply hasn't appeared so I will try again. Here are a couple of pics which illustrate my question. I think Sixpack577 is referring to the drip rail finishers which you can see in the pictures (I'm not confident they are installed correctly or are undamaged). I am not sure what tabs you mean, Dave03S. Hopefully the picture will answer that as I am not aware of any additional parts. Thanks,
Bob
Upper left corner showing end of windshield top finisher moulding, drip rail finisher tip, and gap which goes down into the A-pillar
Upper right corner showing end of windshield top finisher moulding, drip rail finisher tip, and gap which goes down into the A-pillar
Old Aug 26, 2018 | 12:53 PM
rfhusband's Avatar
BTW, I have submitted a reply with pictures but am waiting for the moderator to release the post to this thread. Thanks for your replies.
Old Aug 31, 2018 | 01:37 AM
rfhusband's Avatar
Here are the pictures - one more time Right side - mind the gap!
Old Aug 31, 2018 | 01:38 AM
rfhusband's Avatar
And left side photo... Left side
Old Sep 4, 2018 | 12:03 AM
rfhusband's Avatar
Will try again - the pics seem to have disappeared into space...
Right corner
Old Sep 4, 2018 | 12:11 AM
rfhusband's Avatar
Trying again with smaller pictures - the gaps are visible at each end of the upper finisher strip.
Right upper corner - see gap
Left upper corner - see gap
Ben Matheson
Dec 12, 2018 08:15 AM
mr. choodles
Jan 7, 2018 05:35 AM
collector87
Oct 13, 2012 01:37 PM
sharp
Apr 29, 2009 09:05 AM
andrewmcoffin
Apr 5, 2008 10:20 PM
