Disco II bad vibration
Old Apr 2, 2013 | 07:34 AM
Ramon Blandino's Avatar
3rd Gear
Default Disco II bad vibration
I have a Discovery II 1999 with 105,100 miles few months ago I began noticing a strong vibration when I and driving between 25 to close to 40 miles per hours after that truck rum smoothly
Any idea what may be happening
Thanks
Old Apr 2, 2013 | 07:35 AM
drowssap's Avatar
have you ever check you drive shaft?
Old Apr 2, 2013 | 07:53 AM
To put a finer point on it, the front drive shaft. The oem one has some sealed u-joints. When they dry out, it will vibrate and can split without warning, knocking a hole in transmission. That will cost on the order of $7,000 for the dealer to replace. The shaft can be rebuilt for under $100 in parts (in our tech area), or replaced with an upgraded after market shaft by a DIY owner. Grease every oil change.
Old Apr 3, 2013 | 06:37 AM
3rd Gear
Than you for yous answers,
I did have to change the drive shaft around 20,000 miles or 3 years ago because broke and one end just fall in that pavement -the other end remained attached to the truck- I will have it check to verify that sealed u-joints has not dry out.
Old Apr 3, 2013 | 07:42 PM
There is also a rubber coupling at rear differential that sometims cracks.
Disco Fuego
May 14, 2013 04:31 PM
dparham
Apr 22, 2013 04:03 PM
samaro71
Mar 18, 2013 01:13 PM
aBs0lut30
Dec 22, 2011 12:18 PM
Soccer Dad
Jun 6, 2010 06:37 PM
