Disco2 Headlight
Old Oct 5, 2015 | 08:13 PM
chubbs878's Avatar
Default Disco2 Headlight
I have this thing pulled off my truck because condensation has built up in it since I washed it this past weekend. Has anyone separated the lens to clean it from the inside out? It looks like the seal has seperated on the top and is the cause of my problems so I am going to message the man whom I purchased it from. I'd like to get behind the main lens but I'm not seeing an easy way. Also I have a Turtle Wax restoration kit, which I used on it before with only minor results to the outside as this is not where the oxidation and film is laying
Old Oct 5, 2015 | 08:14 PM
chubbs878's Avatar
Behind the lens?
Old Oct 5, 2015 | 08:16 PM
chubbs878's Avatar
Another
Old Oct 5, 2015 | 08:33 PM
Alex_M's Avatar
You can. If you do, go over to one of the modifications sections (cant remember which one) and retrofit HID projectors. I did mine and it turned out awesome! But be warned; buy quality projectors and aim them carefully.
Old Oct 5, 2015 | 09:21 PM
chubbs878's Avatar
I found the thread and indeed I would have to heat up the HL assembly in the oven, remove the entire lens and re-glue it back into place. I will save this project for another time but thanks for pointing me to that thread. I know what I need to do now
gmfain
Feb 16, 2015 09:37 AM
camgkh
Jan 18, 2015 11:42 AM
Disco03
Dec 1, 2008 08:08 PM
felixx23
Jun 2, 2005 12:05 AM
kartoudi
Dec 11, 2004 04:47 AM
