Discovery 2 4.0 v8 low on power high fuel consumption
Old Mar 13, 2025 | 09:27 AM
H20nSnow's Avatar
Originally Posted by wbalys
I cleared the codes and it runs slightly better, but the knock sensor came back right after.
To be clear, he didn't mean "clear the codes", he meant solve the problems that trigger the codes. Apologies if you understood that.
Old Mar 13, 2025 | 11:41 AM
jastutte's Avatar
he may have meant "clear the codes". that way you can see which codes come back and in which order. some of the codes originally displayed may no longer be relevant.
the knock sensor code coming back first is a good clue on where to start looking first.
Old Mar 13, 2025 | 08:21 PM
JohnZo's Avatar
The ECM pulls timing if the knock sensor activates, so yeah, gutless and thirsty. Now the question is why does it activate?
Old Mar 14, 2025 | 04:28 PM
wbalys's Avatar
I have switched the spark plugs and nothing changed. Wires are good too. Only concerning thing was wet and black spark plug at cylinder 7. Other plugs were clean and dry.
I bought new knock sensor yesterday to be sure its working and not showing fake values. it should arrive at monday.
Second thing I noticed was a lot of white smoke coming from the exhaust when idling, though it disappears when I start driving. Could this be a problem with the valves strictly at cyl 7?
And the last thing and probably the worst is crack i found near cylinder 3. How bad is it?
Old Mar 14, 2025 | 04:34 PM
wbalys's Avatar
Right, I saw where you said that. I'm questioning whether the LPG conversion kit is any good at all. It is possible that it has compromised everything. That was the perspective of my question, and why I wondered if you had been able to dig deeper with the previous owner. "Yeah, I had better mileage before I added LPG, but I needed it so bad I lived with the negatives." That sort of thing.
I didn’t contact him about it yet, but if the problem continues I will ask.
Old Mar 14, 2025 | 04:51 PM
wbalys's Avatar
And I forgot about cooling system.
It’s boiling and damping coolant from reservoir.
I’ve bleed the system yesterday and problem returned. The waterfall sound from the heater is present too.
Old Mar 15, 2025 | 02:12 AM
JohnZo's Avatar
How bad is the crack? The good news is nothing is leaking out. The bad news is a boiling coolant reservoir could be from exhaust leaking into the cooling system, for example a bad head gasket, or a crack between the exhaust and coolant passages in the cylinder head. Maybe try using a tester with the blue liquid chemical that turns yellow if exhaust gas is detected. At least, a compression test is in order.
PS White smoke could also be from coolant in combustion chambers.
Old Mar 15, 2025 | 10:13 AM
wbalys's Avatar
Edit: the white smoke is gone. I started it this morning and no smoke
Old Mar 30, 2025 | 04:49 PM
wbalys's Avatar
Hi, last week I had no time to work on my disco, but today I tried to drive with maf unplugged. It had rough idle at first but it got better. With maf unplugged it has noticeably more power between 1500-3000rpms and the biggest change was full consumption which was 15l/100 instead of 23-25l/100. So i think its gotta be a maf sensor. I contacted the seller too and he told me that disco was parked for 3 months before he sold it and before he parked it consumption was 15-19l on 35' tires (now its on small winter tires) which had me thinking about ecu water damage because 2 months ago in my td5 disco bcu got water damage what lead to always flashing hazard lights. My mechanic told me he will borrow me working maf sensor to check if it makes any difference. If not, that car electronic specialist who repaired bcu is my next destination.
Old Mar 31, 2025 | 09:59 PM
evil_goat's Avatar
Try scraping the crack with something. I had something that looked similar and I thought it was a crack, but it was just oil residue.
carltb
Oct 5, 2024 06:25 PM
BADidOl
May 6, 2023 11:23 AM
MrTortoise
Sep 29, 2017 02:37 PM
leonpronk
May 3, 2017 12:07 AM
ctjawadisco2
Feb 19, 2009 02:39 AM
