Discovery 4.0 to 4.6 Swap?
Old 01-20-2009, 08:00 PM
MarvelVT's Avatar
Default Discovery 4.0 to 4.6 Swap?
I have a 1997 Discovery (I) with the 4.0L engine. I also have a wrecked1998 Range Rover with the 4.6L engine. Can I swap both the engine and transmission from the Range Rover to my Discovery? The Range Rover transmission shifts much better.
Thanks in advance.
Old 01-20-2009, 08:07 PM
AK Rover's Avatar
Default RE: Discovery 4.0 to 4.6 Swap?
I know the engine i a simple drop in conversion. I would think that the transmission would be a pretty simple swap also. You may need the computers from the RR also but I don't know for certain.
Old 01-20-2009, 08:19 PM
You will need the transmission ECU since the DI uses a old style non electronic transmission.
You will also need the engine ECU.
Old 01-21-2009, 08:30 AM
MarvelVT's Avatar
Are the ECU swaps just a matter of changing the units or are there wiring modifications that will be involved?
Thanks
bennyb43
12-11-2013 08:17 AM
Wildhorse1966
04-03-2009 12:22 AM
miyadog1
03-05-2009 11:08 PM
Kennyr996
12-05-2007 05:25 PM
Quick Reply: Discovery 4.0 to 4.6 Swap?
