Discovery check engine warning
Old Nov 1, 2008 | 02:04 AM
veggienut's Avatar
Default Discovery check engine warning
Hy'all,
I have recently purchased a Discovery 2? 1998300TDI SE auto.
When driving along at any speed, when I lift my foot off of the throttle, the engine appears to die or revs suddenly drop off and the check engine warning light appears simultanesly. As soon as I increase the revs the engine picks up again and the warning light dissapears.
Has anyone got any ideas as to what this problem is?
Thanks!
Arf
Old Nov 1, 2008 | 09:39 AM
Default RE: Discovery check engine warning
Sorry, you probably won't get a reply from us, none of us are lucky enough to have a diesel.
Wish we could help.
Old Nov 1, 2008 | 02:10 PM
Disco2Guy's Avatar
UrbanPanzer is your best bet. He has an '01 TD5.
Old Nov 1, 2008 | 03:08 PM
You have a DI. Change the fuel filter and then have the injector pump looked at. It sounds like a fuel delivery problem.
Old Dec 3, 2008 | 11:19 AM
pb_salomons's Avatar
I have the same Discovery and i have the same problem. landrover told me it might be the injector with the electronic sensor inside or the crankshaft positioning sensor. i am going to exchange and hoping it will work if you have allready solved the problem please let me know how.
cipher982
Nov 9, 2019 11:22 AM
FlyingZebra34
Feb 22, 2014 05:39 PM
shmassey1@roadrunner.com
Oct 30, 2009 07:44 PM
filind1014
Sep 21, 2009 11:04 AM
fatman007
Sep 5, 2009 03:07 PM
