Discovery II Dashboard Repair Kit...
Old Jun 20, 2020 | 05:19 PM
  #31
Discorama's Avatar
I glued one warped end of the dashboard with the same glue about two years ago, and it still holds (always parking outside in the sun). There are two small bumps which came up again, but this is visible through the windshield only (I don't care).
Old Jun 20, 2020 | 07:29 PM
  #32
Discorama's Avatar
Yes it does. Only two small bumps that cam up again, but it's not visible from inside, only outside (I don't care).
Old Sep 26, 2021 | 01:23 PM
  #33
Paisley's Avatar
4wd High
Originally Posted by Discorama
I just glued my warped dashbord. When it's hot and sunny and the car is parked in the sun, the dashbord gets quite soft. I used a heat gun in addition and it got very easy to push it down. I used Aquaseal, which is an urethane glue (pls see below). To get the glue underneath the dashboard I used a syringe with a thick bent needle. When the glue is warm, it gets very fluid and can be pushed through the needle. Letting the tube sit in the sun for a few minutes is sufficient. The heat gun can be used to heat the glue up more, especially the glue in needle.
https://www.amazon.com/Gear-Aid-Aqua.../dp/B079YNC13G
Excellent! I’ll be trying this out as soon as my Aquaseal arrives. I’ll report back on longevity.
losinov
Sep 11, 2019 08:24 PM
jerichards93
Aug 17, 2018 07:58 AM
Aj6543
May 7, 2018 04:17 PM
earlyrover
Jun 17, 2016 09:05 AM
nick1996rover
Feb 12, 2005 12:46 AM
