Discovery with no Drive/ tranni problems
I have a similar problem in my Disco 98 automatic 4.0L V8, I was driving on mud, I hit a hole and at the same time someone pull the emergency brake accidentally. when I tried to drive again, the eng rev but it does not drive (it was shifted on D), I shifted to 1 and it drive again, then I shifted to 2 and good, the shifted to D and every good. but if I stop the car, happen the same so I need to start over 1,2,D. the trans shift smooth, no problem, just that I need to start driving on 1 the switch 2 and D. any ideas???
And you might want to review the RAVE about the automatic transmission XYZ switch, it is mounted on side of tranny and may have been knocked out of adjustment, or full of gunk. It is in the attached drawing.
The DI does NOT have a XYZ switch.
Might be a good idea to change the filter too.
If that does not do the trick you need a power flush with a special solvent to clean up the gunk that has accumulated inside the valve body of the transmission.
If it still does not work right you need a new transmission.
I have the same problem
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
Randy P
Sep 27, 2007 08:27 AM
