Discovery with no Drive/ tranni problems
Old Feb 26, 2010 | 11:04 PM
njb8199's Avatar
03 d2 hse
Old Oct 29, 2011 | 02:02 PM
djgg511's Avatar
I have a similar problem in my Disco 98 automatic 4.0L V8, I was driving on mud, I hit a hole and at the same time someone pull the emergency brake accidentally. when I tried to drive again, the eng rev but it does not drive (it was shifted on D), I shifted to 1 and it drive again, then I shifted to 2 and good, the shifted to D and every good. but if I stop the car, happen the same so I need to start over 1,2,D. the trans shift smooth, no problem, just that I need to start driving on 1 the switch 2 and D. any ideas???
Old Oct 29, 2011 | 02:29 PM
Danny Lee 97 Disco's Avatar
Try Paul Grant and Will Tillery for a deal on used parts.
Learn more about your Discovery so you do not tear it up playing.
Old Oct 29, 2011 | 03:21 PM
And you might want to review the RAVE about the automatic transmission XYZ switch, it is mounted on side of tranny and may have been knocked out of adjustment, or full of gunk. It is in the attached drawing.
File Type: pdf
Old Oct 30, 2011 | 10:02 AM
dogandpony's Avatar
6th Gear
The Xyz switch did not fix my problem. I bought a used transmission and installed it. That was fun...... Anyway, I have not yet pulled the oltd tranni apart to see what failed.
Old Oct 30, 2011 | 05:11 PM
The DI does NOT have a XYZ switch.
Old Oct 30, 2011 | 05:13 PM
Start by changing your trans fluid, if it got water in it it can cause problems.
Might be a good idea to change the filter too.
If that does not do the trick you need a power flush with a special solvent to clean up the gunk that has accumulated inside the valve body of the transmission.
If it still does not work right you need a new transmission.
Old Jul 18, 2022 | 02:40 AM
kru4marov's Avatar
hello, did you resolve the problem?
I have the same problem
DiscoJon
Jul 14, 2019 01:51 PM
HWilburn
Aug 13, 2011 09:16 AM
TripleThreat
Apr 12, 2011 08:58 AM
salve7
Aug 19, 2009 12:50 PM
Randy P
Sep 27, 2007 08:27 AM
