Discovery Noisey Gearbox
Old Feb 2, 2011 | 11:05 AM
Originally Posted by Eak69
Not to hi-jack the thread but I have been getting a similar noise in the last week.
It sounds almost like your serpentine belt 'chirping' as I drive - and it's not the belt - or the engine.
When I give the car gas - it 'squeaks or chirps' and it stops when I stop giving it gas.
It doesn't make the sound when the car is moving and I put it in neutral, or when it is in neutral and I rev it up - its not the engine, its not the brakes, so I am assuming it is either the (ATX) tranny or gear box.
My next step was to check and change the fluids as I JUST changed the fluid in the front axle (just in case).
I do notice a small leak coming from the back by the tranny - which anyone can see it is a sign something is going on.
So the faster I go while giving it gas - the faster it chirps. Almost like some metal on metal rubbing - but I can't find the sound.
Thanks!
Read this and stop driving your truck.
https://landroverforums.com/forum/sh...ad.php?t=37853
Old Feb 2, 2011 | 12:53 PM
First, never assume anything when it comes to your Rover, bad mistake.
Try driving in low range, do you still get the same noise? Is you still have the noise, I would rule out the t/case and say it is the tranny and even heavier oil won't stop the noise or wear at this point. I would suggest you find either a shop that can rebuild it or buy a good used one cause although your friend says it will last, it won't.
Old Feb 2, 2011 | 03:17 PM
Eak69's Avatar
I actually read that before this post came up...
It started while I was about 300 miles away in Cali and I thought it was my brakes squeaking or something.
I will try to drive it in a low gear to see if the noise goes away. I do hope it is just the U joint - but we shall see.
Thanks for the input!
Old Feb 2, 2011 | 03:53 PM
lordmorpheus's Avatar
Eak, I believe Mikes reply was to the OP of this thread. That's why I suggested starting a new thread, so replys don't get confusing.
Old Feb 2, 2011 | 10:01 PM
Eak69's Avatar
Done and DONE!!! Thanks - started a new thread:
https://landroverforums.com/forum/sh...138#post224138
Rferguson
Aug 15, 2013 09:33 PM
colin2496
Nov 5, 2009 09:05 PM
Suede
May 16, 2009 05:32 PM
Spike555
Jan 12, 2009 10:49 AM
