Displaying Oil Pressure Options
Old Dec 4, 2024 | 06:37 AM
PickleRick's Avatar
I've not had any luck with cheap sub 50 dollar boost gauges with electric sensors in the daily driver. Been through two of them in 2 years time. The electric sensor 52mm oil gauge has, knock on wood, been great. I now run a glow shift boost gauge.
Yeah I run the same cheap Chinese boost gauge in my boat for the past 5 years without an issue.
So far the Disco has only gotten glowshift gauges however in the past I've always had good luck with auto meter.
Old Dec 4, 2024 | 06:39 AM
PickleRick's Avatar
Forgive me as I forgot it's in proper to post a picture of a boost gauge without a reading at least 10-15 lb
Old Dec 4, 2024 | 09:04 AM
longtallsally's Avatar
Originally Posted by Extinct
Tee fitting will work, I have done it. I have used the innovate motorsports MTX-D oil temperature and pressure gauge quite a lot as it has programmable alarm (flashing oil pressure numbers or flashing led's for temperature. I use the oil temperature sensor for coolant temperature, works fine. https://www.innovatemotorsports.com/...mperature.html If you have an 03-04 you can use the unused oil cooler port (LS engine oil pressure adapter works), on a 99-02 you can also use the plug higher up. Fits nicely in our new gauge pod.
https://extinctmotorsports.com/adjus...gle-gauge-pod/
Yeah I’ll be ordering one of those pods once I’m back to the Disco as my install on the ‘00 wasn’t quite that clean.
And a couple folks mentioned the canister style oil filter. My Jeep has one of those and you guys will laugh at the factory part (not kidding) to be able to take a reading from the year Wrangler it is. The cap for the filter housing is simply drilled and plumbed to where a sender can be screwed in and a pressure reading taken. I just installed in permanently again with Glowshift stuff. I did a T fitting again so I could get oil temp and pressure. Taking that same logic to my current Discos, that sandwich adapter has more than one port and I could do the same thing- temp and pressure- and have it cleanly installed in the Disco. I like in my Jeep I can see both oil and coolant temp and see when and how they parallel or don’t. A nice feature in the Jeep with a telematics application I have for it is that I can put the electric cooling fan into “hyper” mode, which in a 90 second cycle drops the coolant AND oil temp by over 20 degrees F.
It’s extremely useful as it helped me diagnose an oil pump issue in the Jeep. Again, because I like pics:
Old Dec 4, 2024 | 05:46 PM
Discorama's Avatar
Here is what I did: On the oil pump cover there are two ports. The upper port is plugged from factory. I moved the factory oil pressure switch into the upper port. In the lower port, where the switch was I installed a pressure sensor with a NPT-M12 adapter. This is the ideal location to measure oil pressure, because it is post filter. Into the oil cooler port, which is plugged from factory too ('04), I installed an oil temperature sensor. To display the values I use Torque Pro (Phone App) via a BT adapter.
Old Feb 19, 2025 | 07:21 AM
keninnc's Avatar
Longtallsally,
do you have the model number for the sandwich adapter you used.
Glow Shift’s web site only shows one that has 3/6 - 16 thread per your picture.
The SKU is GS-AOC2.
I’m hoping you can confirm the SKU number.
thanks
Old Feb 24, 2025 | 08:00 AM
Originally Posted by keninnc
Longtallsally,
The SKU is GS-AOC2.
thanks
Hey sorry for the late response as I was getting back to the States and traveling cross country and getting moved back into our home.
I searched in my Email and this was on the invoice I got from Glow Shift for the sandwich adapter: GS-AF2
Hope that helps!
Old Feb 24, 2025 | 04:06 PM
keninnc's Avatar
Thank you...perfect....
MaineLR3
May 30, 2025 04:39 PM
dswilly
Aug 28, 2023 04:35 PM
arains44
Feb 14, 2023 02:50 PM
cvhyatt
Jan 9, 2022 10:35 PM
escott16
Jun 13, 2018 04:14 PM
