Does this sound like a bad wheel bearing???
Old Jul 27, 2009 | 11:00 AM
lipadj46's Avatar
I put a used hub on mine too. Not the best choice but the hub I got looked practically new so we will see how long it holds up. You can get a 300 lb torques wrench from harbor freight for $70. I just torqued it to 300 then a hair more then staked it good.
Old Jun 4, 2010 | 08:27 AM
archebald23's Avatar
was it a direct fit? im planning to install a wheel bearing module myself. after installation, i might just let the garage torque it up.
Old Jun 4, 2010 | 11:22 AM
Darover's Avatar
wheel bearing job takes 45 minutes to an hour per side.
BUT....a in my experience, a wheel bearing going south will emit a whistling, chirping sound . I never saw the 3 amigos come on either and my front right bearing was toast.
Old Jun 4, 2010 | 11:25 AM
Why are you replacing a hub?
Old Jun 5, 2010 | 02:17 AM
skatelove303's Avatar
Deff replace your bearings anyways, I did mine a couple weeks back and ended up having to replace my front right spindle and hub assembly... The bearing race was welded to the spindle...
Old Jun 5, 2010 | 08:27 AM
Rovin4life's Avatar
are your certain the noise isn't from a bearing in the transfercase or the diff? No noise or looseness might be something else. Get a professional opinion to be on the safe side.
ESPN
Mar 2, 2012 10:20 AM
Take THAT, Jeep!
Nov 3, 2011 08:48 PM
NiveK1970
28
Nov 24, 2009 11:41 PM
Aquaholic
Jun 15, 2007 10:30 AM
