Replacing a 3.9 V8 with 300TDi. What is needed?
Old Dec 21, 2009 | 11:13 AM
johnkbl's Avatar
Default Replacing a 3.9 V8 with 300TDi. What is needed?
Hello!!!
I am looking to change my 3.9 V8 and instead of that, put a 300TDi. Do I need to change also the Gearbox? Are there any other major changes that I also need to do? Is it easy?
Old Dec 21, 2009 | 09:33 PM
You will need the ECU, mod your fuel system, install a intercooler, change your exhaust and a few other things I am not thinking of.
As long as it is a Rover diesel it will bolt right up to the transmission.
Double check that you dont need a TDI bell housing, but I am 99% sure you can use yours.
Old Dec 22, 2009 | 10:42 AM
Rovers from the factory have a different gearing in both the tranny and t/case. If you use the stock tranny and t/case, if you still need to look at gearing, then go to your diffs.
BrianH
Engine & Internal
May 31, 2011 01:02 AM
kymike
Apr 24, 2009 01:17 PM
Cleggy
Mar 4, 2006 06:34 AM
stouty
Dec 5, 2005 04:47 PM
esblandrover
Jun 23, 2005 07:19 PM
