door check replacement
Old Jan 10, 2026 | 04:02 PM
H Hill's Avatar
My bracket has now broken the weld at the A pillar. I removed the roll pin and currently catch the door bottom with my left foot or with my left hand on the door handle. Going to have my engineer brother who owns a steel fabrication company to come up with something. Perhaps bolted from the outside. Not interested in repainting the A pillar after welding. Will keep everyone posted. My truck is a daily driver with 318K miles on it, so the door’s been opened a lot. 😉
Old Jan 10, 2026 | 04:11 PM
mackendw's Avatar
That sucks....sorry to hear that. wind catch the door?
Old Jan 11, 2026 | 08:25 AM
H Hill's Avatar
No, just eventually broke over time. Had a body shop repair it about 8 yrs ago, did a good job, welded and repainted, cost a bit. But has broken again. The bracket on the A pillar is loose and no longer attached so I removed the pin and pushed the retaining strap into the door.
Now I make sure to catch the door
Old Jan 14, 2026 | 02:58 PM
Roont's Avatar
Mine is snapped also and looks like someone did try to weld it once. I am going to try to just rivet in webbed straps like my Jeep has. I don't think there's any material left to weld after I cut away the snapped broken welded parts.
Old Feb 3, 2026 | 04:41 PM
mackendw's Avatar
got the bushing installed. no more noise when opening/closing the door. had to do a bit of fashioning of the bushing to get it in. snug fit.
NOTE: I had to pick up a 12" extension and a 23/64 hex style end drill bit for the extension to drill out the wallowed hole. to get the hole 100% straight/centered. this left 1mm
fo play with to fit the bushing in. a few swipes with a round file in the hole and it went in licked-split.
Old Feb 3, 2026 | 08:06 PM
Extinct's Avatar
Pics?
Old Feb 3, 2026 | 08:46 PM
mackendw's Avatar
Originally Posted by Extinct
Pics?
here ya go:
the scuff marks were from the file to remove the burrs when I drilled the hole out. paint touch up required.
Old Feb 4, 2026 | 12:29 PM
Extinct's Avatar
I must have misunderstood, I thought the innovative bit was the attachement of the bracket to the door jamb?
Old Feb 4, 2026 | 12:32 PM
mackendw's Avatar
2 separate isues. on my rig, the bracket is solid on the A pillar. The hole for the pin holding the door check strap was wallowed out.
gte619n
Oct 14, 2022 01:37 AM
carlyla
Aug 5, 2015 08:30 AM
coors
Aug 2, 2013 03:05 PM
hallfleming
Jul 29, 2011 05:14 PM
mcneal
Oct 25, 2007 02:21 PM
