Door check strap
Old Apr 16, 2021 | 09:04 PM
rOverlanding's Avatar
Default Door check strap
Hi guys. A year or so ago I removed the pin that connects a door check strap with the body because of the loud popping sound when opening and closing (the piece attached to the body is loose). Recently I tried to fix it by using JB Weld SteelStik but it didn't work. Is welding my only option in this situation?
Old Apr 17, 2021 | 05:11 AM
The Deputy's Avatar
Yes, welding would be the best fix, besides replacing door, but replacement would only be if it was unweldable (rust or cracked beyond repair). Just find a shop that specializes in welding, they'd be able to correct this.
Old Apr 17, 2021 | 02:27 PM
Tony Luna's Avatar
I did this a couple of years ago. Hard stainless plate. Cut it on a bandsaw, filed clean. Range Rover clevis. Bolted the clevis to the plate. Riveted the plate to the door frame.
Old Apr 17, 2021 | 03:14 PM
To sustain my clean record in terms of self-reliance in fixing my Rover I was thinking about fixing it myself. I was thinking about renting/buying a welder and fixing it but there is one small problem... I never welded before. I am a quick learner though. How hard would it be to fix it for someone without any prior experience with welding?
Old Apr 17, 2021 | 05:19 PM
Harvlr's Avatar
Welding thin steel is quite difficult, especially if you don’t want it to look like crap
Old Apr 17, 2021 | 06:04 PM
Tony Luna's Avatar
I can weld - that’s why I opted to rivet a plate.
Old Apr 17, 2021 | 06:43 PM
I really like your solution. I will try that. Thanks for the idea.
Old Jan 14, 2022 | 09:18 AM
TimInNova's Avatar
Tony never mentioned it, but I figured out that the "clevis" he used is part number ALR3733, from the P38 RR.
https://www.bearmach.com/product/doo...lr3733/ALR3733
I hope this helps anyone looking into doing this fix.
Old Jan 15, 2022 | 09:53 AM
H Hill's Avatar
Excellent fix. Though I've had the driver's door welded at my local body shop (did a nice job, including refinishing the jamb), I'll keep this idea and the part # (thanks TimInNova) for future reference.
maho
Jul 31, 2017 11:45 AM
rayxlee
Sep 15, 2014 07:52 AM
TRIARII
Jun 16, 2014 08:45 AM
coors
Aug 2, 2013 03:05 PM
