Door lock actuators success, part num for torx bolts to attach it?
did both front door lock actuators. it was intimidating, however after getting inside the door it was fairly straightforward to do the full frame removal. i did not find that very challenging, much less than the frame bend and try to muscle the lock around it in place.
one challenge was the 3 torx bolts that hold the actuator to the door frame. on both sides i had to drill one out. any idea on the part number or where to order some replacements? t25 if i recall from the bits i bent trying to get them out.
thanks.
thanks.
bcolins
10-02-2008 05:40 PM
