Door lock actuators success, part num for torx bolts to attach it?
Old May 10, 2014 | 03:25 PM
nosup4u's Avatar
Default Door lock actuators success, part num for torx bolts to attach it?
did both front door lock actuators. it was intimidating, however after getting inside the door it was fairly straightforward to do the full frame removal. i did not find that very challenging, much less than the frame bend and try to muscle the lock around it in place.
one challenge was the 3 torx bolts that hold the actuator to the door frame. on both sides i had to drill one out. any idea on the part number or where to order some replacements? t25 if i recall from the bits i bent trying to get them out.
thanks.
Old May 11, 2014 | 05:31 PM
nosup4u's Avatar
in the short term i took a couple off the rear doors to fill the gaps in the front.
Old May 14, 2014 | 12:10 PM
nosup4u's Avatar
for future reference the torx screws are part number fyp101220
acg
Feb 7, 2021 09:44 AM
rekogniz1
Oct 8, 2009 12:08 PM
shonuff93
Aug 11, 2009 12:39 PM
wesley64
Oct 5, 2008 10:49 PM
