door wiring ?
Old Aug 11, 2013 | 08:37 PM
parkerlander's Avatar
Default door wiring ?
Hi, any chance if someone knows on a 99 disco II ( I've read the damn rave for hours and cant find the answer) if any one of the wires in the front door wiring harness has 12v power when the ignition is turned on? Looking to add a 12v power line to an illuminated speaker without running to the fuse panel.
Thanks!
Old Aug 11, 2013 | 09:04 PM
dgi 07's Avatar
Window motor. But for the love of sweet baby jesus, whats the problem with running it back to the fusebox. Do it right. Add a small fuse panel and run it correctly. Prevents future problems. If you do it the way you want to, you will burn the harness out.
Old Aug 12, 2013 | 09:43 AM
yea already did .........I could not find e the wiring schematics for the door harness so I just ran it back through the rubber door boot. Kind of PITA but, done now
Thanks!
coors
Jan 31, 2015 06:36 AM
chicane
Feb 19, 2014 12:37 PM
KGN96discoSE7
Apr 4, 2010 09:05 AM
CandiMan
Aug 24, 2008 10:35 PM
99XJ
Sep 29, 2007 08:37 AM
