Double Cardan question
Old Mar 3, 2022 | 11:08 AM
me 2's Avatar
Default Double Cardan question
I might not understand what Double Cardan means but seems the oem front prop shaft I installed has Double Cardan joints already! If so why is it mentioned everywhere to replace the prop shaft with a Double Cardan shaft for a high lift? Just curios if Im confusing this.
Old Mar 3, 2022 | 11:51 AM
Alex_M's Avatar
The oem shaft is a double cardon driveshaft. If you go to a big lift, you need to swap to a *multiple* double cardon shaft, meaning two universal joints at each end of the shaft (four total).
You should also replace your rear driveshaft with one that has a double cardon joint one end and a single universal joint (instead of the rubber donut... Blanking on the name right now) on the other end.
Old Mar 3, 2022 | 12:30 PM
me 2's Avatar
Man, multiple double cardon prop shafts are hard to find. Most are just 3 joints, even the Tom Woods upgraded one.
Bignacio
Jun 30, 2021 01:43 PM
nmacej
Feb 28, 2018 10:57 AM
javasteve
Aug 23, 2013 02:51 PM
Tomzsix
Apr 17, 2013 05:58 AM
disco2adam
Nov 10, 2007 11:02 AM
