draining and flushing
Old Sep 17, 2011 | 08:29 PM
help's Avatar
4wd High
Default draining and flushing
are thier any tricks to flushing i should know about i read the manuall seems simple enoough please let me know
if their are any tricks
Old Sep 17, 2011 | 08:42 PM
buick215's Avatar
Are you referring to the engine, transmission, or transfer case.
Old Sep 17, 2011 | 08:50 PM
R2D2's Avatar
I recommend wiping before flushing.
Old Sep 17, 2011 | 10:18 PM
If cooling system, if you will be removing a hose clamp, keep in mind that rad hose could fail if you are not careful with it. Lower hose might not be in stock locally. Main trick will be getting air purged from system upon re-fill, lots of posts on these. There is a drain plug on a D2, but not on D1.
When you said read the manual, you do have a copy of the RAVE, with all the shop manuals, owners manuals, etc.? Free below.
If transfer case, see D1 Transfer Case Fluid Change with Pictures - Land Rover Forums - Land Rover Enthusiast Forum; and be sure fill plug can be removed before draining. Works better if you back truck up on to ramps, nose down, safety truck so it can't roll off and squash you.
If tranny, see https://landroverforums.com/forum/di...-filter-34270/, getting pan off can be an issue.
The RAVE gives lots of info, and sometimes in our techsticky area you get some pictures o go along with that.
Old Sep 18, 2011 | 07:20 AM
Or power steering or ACE?
Nedd more information from you.
Old Sep 18, 2011 | 08:08 AM
And truck type and location - (Flushing NY ?)
458steve
Dec 23, 2010 10:54 PM
04discomw
Feb 15, 2010 05:59 PM
Chrisinhouston
Feb 19, 2008 05:02 PM
jamieg
Aug 29, 2006 12:26 PM
Evian
Sep 10, 2005 01:39 AM
