Driver Side door will not open!!
Old Dec 28, 2009 | 11:20 AM
DooDer's Avatar
Default Driver Side door will not open!!
Hey Y'all!
I replaced the dirver side door actualtor a week ago and a couple of things have happened. First the driver's door no longer opens from the inside and out and second, the horn beeps when I lock the doors. I was told from an older post that I must have disconnected something when I replaced the actuator but my biggest problem now is getting the door open in the first place. How do I open the driver's door without the use of the handles inside or out?!!!!
Dooder
Old Dec 28, 2009 | 07:41 PM
SDinDS's Avatar
Had the same issue when I bought my Disco. Driver's door didn't open at all. I was able to get the door open by removing the door panel (a pain when it won't open, but it can be done) then I disconnected the linkage from the outside handle and pulled on the inside handle to open it. Don't know about the horn beeping unless you disconnected the wire to the door handle.
Eric
Old Dec 28, 2009 | 09:42 PM
DooDer's Avatar
thanks! I'll give it a shot.
SuperSport
Jul 23, 2014 01:04 PM
toofaroffroad
Dec 22, 2013 12:17 AM
nycranger
May 5, 2013 05:23 AM
darren24
Aug 6, 2012 05:21 AM
