Driver side read door won't open
Old Dec 21, 2013 | 02:15 PM
toofaroffroad's Avatar
Default Driver side read door won't open
2000 D2 approx 125 miles.
Well this came out of the blue last night. The driver-side rear door had no problems at all and all of a sudden last night I cannot open it. I didn't want to start attempting to rip door panel off before checking with the forum.
The lock will pop up and pop down with fob and central and with key in door but the outside handle acts as if the door is locked. My one ace in the hole is that the door DOES have the child safety switch ON, so i'm hoping that if I can access it somehow then I'll at least get the door open from the inside. If I start taking the door apart while still shut, can I eventually access the child safety switch? Looking on the other rear door, I think it can be done. Might need a bit of bent flat metal to flick it though.
Any help would be great. Thanks Forum.
Old Dec 21, 2013 | 05:49 PM
I love Land Rovers. Went out to give it another go before trying to pull the inside panels off. Wouldn't budge so I started lightly knocking the outside door handle with a rubber mallet….and it opened. Seems to be all good right now.
Old Dec 21, 2013 | 07:42 PM
dusty1's Avatar
If that knocked the release mech. Enough, I would spray some lube in there. I use lithium and/or silicone wd 40, on mine.
Old Dec 21, 2013 | 10:48 PM
roverdrj's Avatar
Mine locked up not too long ago and just used wd-40 on it, no issue since. I lube it regularly now.
Old Dec 22, 2013 | 12:17 AM
Thanks for the reply. I'll spray them. Where do you spray? right where the mechanism attaches?
SuperSport
Jul 23, 2014 01:04 PM
nycranger
May 5, 2013 05:23 AM
Kinz384
Mar 8, 2013 06:43 PM
darren24
Aug 6, 2012 05:21 AM
DooDer
Dec 28, 2009 09:42 PM
