Driver side rear window foam.
Old Mar 27, 2014 | 10:33 PM
Quinn519's Avatar
Default Driver side rear window foam.
Hi all.
I need to know what the foam on the window track is call?
It's the vertical foam/felt/gasket thing that keeps the water and air from getting in.
It is missing on the outside and inside window track frame.
It's about a quarter 1/8 of an inch thick.
Thanks the help.
Old Mar 28, 2014 | 04:02 PM
SuperSport's Avatar
Old Apr 17, 2021 | 04:23 AM
ss_0001's Avatar
7th Gear
Old thread I know.... but I just received this part ASR2096 and notice it’s only long enough for one side and the top. What’s the part number for the other half of the channel runner?
thanks
Old Apr 17, 2021 | 05:03 AM
zski128's Avatar
I don’t know the part number but if the felt is missing it usually fell down into the door. Have you removed the door card and plastic to look inside the door?
Old Apr 17, 2021 | 05:17 AM
ss_0001's Avatar
7th Gear
Thanks, actually if was hard as a rock and shattered when I removed it. Still none the wiser though for the part number so I can buy a replacement.
Old Apr 17, 2021 | 09:58 AM
Dave03S's Avatar
Maybe you could use one of those old style phone things that repel millennials... A vendor could probably tell you and get you the correct part.
Old Apr 17, 2021 | 11:18 AM
ss_0001's Avatar
7th Gear
Millennial....? Think I was born about 20 years too early for that 🤪.
Yeah I did call some parts places here, but all they came up was the part number for what I already just received.
Old May 8, 2021 | 03:37 PM
ss_0001's Avatar
7th Gear
So, the part number for the other half of the window runner is MTC9177. See the diagram below, part labeled 7.
CollieRover
Feb 9, 2015 05:51 PM
justdp
Dec 20, 2011 11:31 AM
tornado_735
Nov 10, 2009 05:11 PM
nickd503
Oct 13, 2009 09:27 PM
