drivers side passenger door lock is frozen...
Old Jul 24, 2006 | 09:18 PM
Brad S1's Avatar
Default drivers side passenger door lock is frozen...
The locks were working fine up until today, I locked the car with the fob and this door didn't respond, I jiggled it a little, then it started responding.. I go outside just now and it's locked, but the fob won't unlock it... So I decide to unlock it by hand... and the lock is jammed down in the lock position, I can't seem to pull it up.. what do you guys think?
Old Jul 25, 2006 | 10:50 PM
Brad S1's Avatar
Default RE: drivers side passenger door lock is frozen...
Well I took all the trim off the door, it was the power lock actuator, it was seized in the down position. I unlatched it and removed it.. Where is a good source to get new ones?
Old Jul 25, 2006 | 11:26 PM
You could try Rover Connection, DAP or Atlantic British. If they don't have them call the dealer.
Mike
Old Jul 26, 2006 | 02:47 AM
Brad S1's Avatar
I called the dealer, I couldn't tell if they were joking or just thought I was an uber yuppie that doesn't know any better, but they wanted 250... I'm pretty sure I could rebuild this thing for less than 5 dollars... I might take it all apart and see what makes it tick, I could possibly build something better.
Old Aug 7, 2006 | 01:51 AM
katbri's Avatar
Brad S1- Did you replace it?? Both of my locks in the back don't work. Has anyone ever done it yourself?
cosmiccharlie
Aug 12, 2020 01:42 PM
kpl1228
Aug 19, 2012 05:33 PM
bsnapp818
Mar 2, 2010 01:52 PM
llPANCHOll
May 2, 2009 02:39 PM
discolvr
Jan 18, 2009 05:46 PM
