drivers side top tansmision core pipe
Old Mar 28, 2015 | 06:58 PM
Prozachd's Avatar
4th Gear
Default drivers side top tansmision core pipe
First off the part that connects to the radiator was missing the plastic piece so moved on to the tansmision side thinking I could replace the oring and be done. Seems as though I have stripped the nut that connects to the transmission. So moved on to the complete replacement. Now I can't even get the old lin out. Any help would be appreciated
Old Mar 29, 2015 | 08:33 AM
Alex_M's Avatar
Use something like vice grips or channel locks to pull while you unscrew it.
Old Mar 29, 2015 | 08:34 AM
Alex_M's Avatar
Unless you mean you stripped the nut itself, which means you need to file or Drexel down two sides so you can get an adjustable wrench down on it.
Old Mar 29, 2015 | 10:55 AM
Prozachd's Avatar
4th Gear
Got the old line out but can't seem to route the new one in.
cosmiccharlie
Aug 12, 2020 01:42 PM
freshdew82
Nov 7, 2012 10:07 PM
Rover Kid
Member Group And Special Buys
Dec 4, 2008 06:52 PM
cosmickites
Defender
Oct 14, 2008 08:40 AM
