Drivers window not working
Old Aug 10, 2019 | 02:28 PM
jdbayer's Avatar
Default Drivers window not working
I swapped out the motor, still doesn’t work. I put power to both motors and they both work. Any ideas?
2003 D2
Old Aug 11, 2019 | 06:51 PM
humroot's Avatar
What happens when you hit the button? Any sounds? I’d check fuses and the switch. When you changed the motor did you reinstall the regulator correctly? I’d also check for 12v at the plug when working the button, that will tell you a lot.
Old Aug 11, 2019 | 07:42 PM
jdbayer's Avatar
nothing happens when I hit the switch. Fuses are good, switch is good. I didn’t have time to see if any voltage was hitting the motor. I’ll do that later this week.
Old Aug 12, 2019 | 03:11 PM
DiscoBuckeye's Avatar
Pull back the rubber flex piece that the wires run through and look for a broken wire.
Old Aug 16, 2019 | 09:36 AM
Did you have a chance to check the wires? This is what I found on mine after changing the motor and regulator
Broken wire prevented window from working
Old Aug 16, 2019 | 01:30 PM
jdbayer's Avatar
I havent had a chance to jump into it yet. I have been upside down with work
I am hoping to get at it over the weekend.
Old Aug 16, 2019 | 02:32 PM
Boy, do I get that. Good luck
nmacej
Aug 7, 2019 08:32 PM
mattaebersold
Aug 6, 2017 11:29 AM
Kilty
Jul 23, 2017 07:27 PM
KingKoopa
Mar 7, 2017 03:50 PM
desertlr3
Dec 3, 2015 04:12 PM
