Driveshaft or alignment?
Old May 6, 2016 | 02:41 PM
Daedrix's Avatar
Banned
Try looking at the front output flange on your t case, its a 30mm nut that sometimes gets loose. Mine was loose and i had vibes at 30mph then 70mph. Here is my tread on the subject it has videos btw https://landroverforums.com/forum/di...bration-78727/
Old May 6, 2016 | 04:54 PM
kjordan's Avatar
Thanks. I'll take a look. My vibration never goes away. I did not install the new center piece for the rotoflex, wonder if this could have something to do with it, also not sure I torqued it down enough. Might just change it out with the lucky 8 conversion. Gonna check out all the bolts on the front shaft again, but I'm pretty sure it's on there well.
So frustrating. Hoping the son didn't do too much damage.
Old May 7, 2016 | 02:10 PM
kjordan's Avatar
Regarding the nut. Is there room to put a socket on it, or do I need something else?
Thanks!
Old May 7, 2016 | 02:23 PM
Daedrix's Avatar
Banned
There is room once you remove the front drive shaft.
Old May 8, 2016 | 03:00 PM
kjordan's Avatar
Problem solved. Thank you!
Old May 8, 2016 | 06:42 PM
Daedrix's Avatar
Banned
Was it the the nut?
Old May 8, 2016 | 08:36 PM
evoblade's Avatar
Originally Posted by WNYErikDiscoII
Off-topic, but that website is pretty slick!
Old May 9, 2016 | 02:08 PM
kjordan's Avatar
Originally Posted by Daedrix
Was it the the nut?
Yep. It wasn't very loose, but that did the trick.
robert.juric
Nov 3, 2022 06:08 PM
DiscoII
Dec 3, 2007 05:18 PM
Waggy23
May 16, 2007 10:00 PM
Bubba_13
Sep 7, 2006 11:05 AM
jomeheretu11
Oct 31, 2005 06:55 AM
