Dropping Sleeve Question.
Old Aug 11, 2007 | 10:08 PM
tailchaser0527's Avatar
Default Dropping Sleeve Question.
My question is about dropping a sleeve. My radiator sprung a leak 8 months ago, and i first noticed it when the engine overheated. Fixed that problem, engine seems to be fine. Water pump hose went about a month ago, engine temp rose again. Fixed hose, no more leakage and motor has been fine ever since. The question: Is the threat of dropping a sleeve and loosing the motor only while the engine is actually overheating, or, am I still in danger of loosing the motor?
Old Aug 12, 2007 | 07:48 AM
Default RE: Dropping Sleeve Question.
The whole trick with any sleeved alloy engine id to not get them hot. If you are wondering if you stand a chance of loosing a sleeve after all this stuff has happened, no. If it is going to drop it will drop when hot and that is the end of the engine.
I would make a point of making sure you have all you leaks taken care of and are using losts of DexCool coolant.
Old Aug 12, 2007 | 10:28 AM
done, and done... I always use 75% dexcool 25% h2o mixture... i've heard anything else is bad for head gaskets. I know theconcept of the alloy and sleeve expanding differently hereby causing major problems, i just didn't know if it caused underlying prob's or not.
Everything has been replaced now, minus head gaskets, so i'm in the clear, for now.
Old Aug 12, 2007 | 10:54 AM
If you are in a warm climate, cut back on the the % of coolant or the adverse will happen and you'll run hotter.
You can also add some of the new coolant additives for even better results.
Old Aug 14, 2007 | 12:13 PM
thanks mike. will do today. your info is always appreciated.
willb285
Jul 24, 2010 04:54 AM
griffker
Mar 16, 2009 07:19 PM
kean
Mar 3, 2009 07:28 PM
chargersfan
Aug 25, 2007 12:22 PM
willb285
May 17, 2006 02:48 PM
