E-Brake questions
Old Aug 29, 2007 | 09:42 PM
shawn's Avatar
Default E-Brake questions
I have removed the drum and searched the cable and can't find the adjustment for my 99 Disco's e-brake. Am I over looking it? Does it even exist? I am having problems with my pads rubbing when the handle is fully released. My pads show signs of spinning instead of holding wear, but no metal to metal. It is like the spring that releases pad pressure is weak. Disco Mike you helped me with the first diagnosis, and asked me to follow up with you. I appreciate your help and any advice in the future. I am also interested in the best way to service tranny and transfer case.
Thanks,
Shawn
Old Aug 29, 2007 | 11:17 PM
dow's Avatar
dow
Default RE: E-Brake questions
isn't the ebrake attached to the tranny and not the rear brakes?
Old Aug 30, 2007 | 08:02 AM
I have never had to adjust the e-brake cable but I belive the adjustment is under the e-brake handle, I think.
Old Aug 30, 2007 | 09:09 AM
okdiscoguy's Avatar
ORIGINAL: dow
E-brake is in the drum located on the front of the rear driveshaft. That's why you have to use caution when jacking these things up. The brake only acts on the rear driveshaft.
FlyingZebra34
Jul 4, 2012 10:57 PM
jhewitt1111
Feb 12, 2011 07:44 AM
VToffroad
Nov 27, 2009 10:36 AM
avking
Feb 18, 2009 05:10 PM
desh72
May 5, 2007 01:17 PM
