EASY FIX - Loose Instrument Cowl Cluster, Speedometer housing
So my Disco 2 (2003) had a loose instrument bezel housing cluster cowl (one million names for this thing). The easy fix is to remove the two screws at the bottom (the little plastic pieces break), and use 1-5/8 inch drywall screws.
http://www.homedepot.com/p/Grip-Rite...DWS1/202308453
You might have to thread it by hand at first, before you can fit a phillips heads screwdriver in there.
Very easy fix, thought I'd throw this out there for other disco 2 owners, I assume it's a fairly common problem.
