EASY FIX - Loose Instrument Cowl Cluster, Speedometer housing
Old Sep 18, 2016 | 05:07 PM
huggi's Avatar
Default EASY FIX - Loose Instrument Cowl Cluster, Speedometer housing
So my Disco 2 (2003) had a loose instrument bezel housing cluster cowl (one million names for this thing). The easy fix is to remove the two screws at the bottom (the little plastic pieces break), and use 1-5/8 inch drywall screws.
http://www.homedepot.com/p/Grip-Rite...DWS1/202308453
You might have to thread it by hand at first, before you can fit a phillips heads screwdriver in there.
Very easy fix, thought I'd throw this out there for other disco 2 owners, I assume it's a fairly common problem.
smonk
Jul 3, 2014 05:36 AM
DiscoZen
Apr 21, 2014 07:45 PM
discobob
Sep 29, 2012 04:18 PM
DaveBFoto
Jun 10, 2011 12:22 PM
rewi9d
Nov 25, 2010 11:35 AM
