Easy On The RTV, Gang
Old Apr 11, 2015 | 11:05 PM
Fast951's Avatar
Default Easy On The RTV, Gang
So, before power washing my oil pan this afternoon I wanted to share what I found lurking in the sump where the oil pump pickup lives. Strings of RTV. Because someone before me thought it was a good idea to smear much more than necessary on the oil pan gasket. Then when they tightened the pan they created a bead all along the inside of the oil pan, much of which wound up in the sump.
If you use this stuff at all use it sparingly.
Old Apr 12, 2015 | 11:05 AM
drowssap's Avatar
And let it setup before tightning
Old Apr 12, 2015 | 12:35 PM
dr. mordo's Avatar
Like any tool, it can be misused.
Old Apr 12, 2015 | 02:32 PM
OffroadFrance's Avatar
Light or liberal use only by heavy use is a no, no. Some loons even smear their headgaskets with RTV
Old Apr 12, 2015 | 09:25 PM
Fast951's Avatar
When the oil pan goes back up I'm not using any RTV with the new gasket. Zero. New gasket with the proper torque should seal just fine.
Old Apr 12, 2015 | 10:00 PM
Kenso's Avatar
I applied a very thin layer of sealant in the areas specified by the service manual. Only odd issue I had was a really slow oil leak around the head of one of the bolts towards the middle of the pan. Removed the bolt and applied sealant lightly to the threads and head of the bolt to correct it. Agreed though that you should be able to get the gasket to seal without RTV-ing it to death.
vibrolucky
Off Topic
36
Nov 18, 2013 03:28 PM
LRD2&ME
Aug 15, 2011 05:54 PM
Savannah Buzz
Off Topic
Jul 12, 2011 05:00 AM
zajanatural
May 8, 2009 10:47 AM
JimScream
Jan 6, 2009 02:01 PM
