Ebrake upgrade
Old Feb 26, 2021 | 11:03 AM
SaltyD's Avatar
6th Gear
Default Ebrake upgrade
Relaxing ebrake with caliper and disc. Has anyone done this, thanks.
Old Feb 26, 2021 | 11:25 AM
mollusc's Avatar
Relaxing? Did you mean replacing?
I wouldn't think it would be worth the effort. The e-brake operates on the rear driveshaft. There's always going to be a certain amount of play in the system between there and the wheels, so it's not like it's set up for precise stopping or holding anyway.
Old Feb 26, 2021 | 11:27 AM
Dave03S's Avatar
If you have a problem with your e-brake it is most likely full of gear oil from the leaking rear output of the transfer case. I'd check that first.
Old Feb 26, 2021 | 11:36 AM
SaltyD's Avatar
6th Gear
Default Already off
Yes replacing, on mobile.
The original ebrake was not in great shape and there is an ebrake kit with a caliper a and disc.
Part
Old Feb 26, 2021 | 12:15 PM
whowa004's Avatar
that won't fit discos, that is for series trucks
Old Feb 26, 2021 | 12:47 PM
SaltyD's Avatar
6th Gear
Instructions say it’s good just need to make a slight relocation to handbrake cable.
Old Feb 27, 2021 | 05:43 PM
JUKE179r's Avatar
I’ve seen that brake mod once on a TD5 Disco 2. The owner said if he had to do it all over again, he wouldn’t.
Just adjust the cable linkage and/or check/replace the drum brake pads.
Old Feb 27, 2021 | 08:59 PM
mln01's Avatar
That seems to me to be an example of a solution looking for a problem.
Old Feb 27, 2021 | 10:04 PM
Best4x4's Avatar
Besides one used D2 I bought which had a broken E-Brake cable the LR Drum Brake on the axle is normally a very reliable unit unless like mentioned above it fills up with 80/90w gear oil.
dmenchaca1966
Oct 18, 2018 10:14 AM
hollis
Nov 21, 2014 12:43 PM
pottzie
May 15, 2013 02:32 PM
sforb
May 10, 2009 01:13 PM
smllikphysh
Oct 27, 2008 06:44 PM
