Electric fan option -Ford Fusion
Old Jun 19, 2022 | 09:49 PM
  #21
RA122125's Avatar
Banned
Originally Posted by Art H
As I use my D2 for towing my boat and daily driver duties.. I am liking this mod a lot. Any change in MPG?
To be honest, It's turned into quite a project vehicle for me, so one of the few things I haven't been able to fully measure over short time I've had it is fuel economy. I tend to do something that would effect fuel economy more often than I fill it up. I know that right now my Ultragauge says I'm getting 13.2mpg around town, short trips for testing and grocery store runs type of things, not that many long runs on each tank. But like I said, I never got to establish a good long time running baseline for this vehicle, as it's been a work in progress since I've owned it. And I don't know how reliable the UG is for mpg, although I do reset the full tank every time I fill up, so maybe it's not far off?
I'm looking forward to others continued input on this thread, including what MPG benefits are seen, sorry I don't have that info directly, my D2 wasn't in super shape when I got it.
Old Jun 20, 2022 | 01:07 PM
  #22
Sandman614's Avatar
I've been tracking mine with fuelly.com, when I get some miles on the e-fan I'll post numbers.
Old Jun 21, 2022 | 06:06 PM
  #23
Sandman614's Avatar
Got my DCC controller today. Now to finish some other projects and shift time to install it.
Old Jun 26, 2022 | 12:30 PM
  #24
Sandman614's Avatar
Some before coolant temp vs speed graphs. Went for a drive yesterday evening and this morning, Same route [23.3mi, 248-436ft elevation, average speed 33mph, max speed 60mph, 44mins], Outside temp about 85-88F. Coolant temps look normal, rising when slower/stopped and dropping back down when I speed up. Looking to see how much difference there will be with the electric fans.
Old Jun 26, 2022 | 02:54 PM
  #25
RA122125's Avatar
Banned
That's some awesome info! Is that some of the Fuelly.com tracking info you mentioned before?
I expect you'll a difference in warm up and cool down times and temps, and less high temp spikes as well. This'll be cool to see, Thanks for adding it Sandman614
Old Jun 26, 2022 | 03:25 PM
  #26
Sandman614's Avatar
Nah that's just coolant temp vs speed logged from the OBD port.
Old Jun 26, 2022 | 03:32 PM
  #27
Sandman614's Avatar
found that the Ford Fusion cooling fans and shroud for the 2.0 turbo and 2.5L were a near perfect fit. Its about 1/2-3/4" larger than the radiator core on the D2, and with a 1/2" rubber seal, it literally attaches to the core like it was made for it. OE p/n DG9Z-8C607-D. It's a dual 13" fan and shroud setup, with hwy flaps, wiring, and hose clips. From my research, I estimate it to pull around 2500-3000cfm, which should work even with an LS swap.
2014 Ford Fusion fan, junkyard with wiring $80
Well well would you look at that.. One minor difference and it doesn't fit.. I had searched for a 2014 Fusion and apparently LKQ cross reference thinks the 2013 fan is the same, while it may fit a fusion it won't fit Rover, why don't they understand what we're trying to do here I guess I have to return this or make my own shroud.. I guess I got excited and jumped when I saw one pop up in the local lot.
Edit: With some more searching and comparing part numbers the correct one is indeed from a 2013-2020 Fusion with 2.0 or 2.5L engine
SKU: DG9Z-8C607-J
Other Names: Fan & Motor, Motor And Fan Assembly Engine Coo
Fusion. 2.5L. 2.0L turbo.
Applications: 2.5L. 2.0L W/O HYBRID.
Replaces: DG9Z-8C607-D, RF-287-
Old Jun 27, 2022 | 09:03 AM
  #28
Sandman614's Avatar
Originally Posted by Sandman614
2013 1.6L Ford Fusion fan... Wrong fan orientation
At least it was only a $3 mistake. Luckily they got a 2.0L fusion in since my last visit to the junkyard. The 2nd time extracting the fans is much faster lol.
I did learn that the fan motors themselves are the same, the main difference is the fan orientation.
Old Jun 27, 2022 | 05:14 PM
  #29
Greg_M's Avatar
Could you be talked into putting a tape measure across this unit? I'm wondering if it could work on a D1. Thanks,
Old Jun 27, 2022 | 05:24 PM
  #30
Sandman614's Avatar
Sure 27 1/8 x 18 9/16"
​​​​​If the radiator hose locations are flipped from the D2 you can get the 1.6L Ford fusion fans.
